Hi! Can anyone tell me where can I find informations about the peak/rms audio levels for dvd authoring? I have to make some masters for authoring and I've noticed that if I set the peak audio level to 0 db, the volume will be higher than most other dvd. Sure, I can experience, but I'd apreciate the exact parameters. Thx
I think you should find all the parameters you need here:
http://www.dolby.com/assets/pdf/tech_library/46_DDEncodingGuidelines.pdf
At least, for AC3 encoding - which is pretty much standard for commercial DVDs.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 20:48 -
Sound Levels when playing Movies
By zenzen1 in forum AudioReplies: 3Last Post: 4th Feb 2010, 22:40 -
Sound Levels
By wolfnature in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 13:02 -
OK, one more time: IRE levels from AVI capture to DVD authoring
By sanlyn in forum Video ConversionReplies: 3Last Post: 13th Jun 2008, 14:54 -
AKAI LCT2721AD Cant program the remote and very poor sound levels.
By ibex333 in forum DVB / IPTVReplies: 2Last Post: 14th Apr 2008, 11:01
