hello everyone, while using DDX, i came across this problem which really annoyed me. at first, ripping the first part of the DVD was fine, then i moved onto the second part and this just came up:
so i decided to wait it out, then i fell asleep, woke up 6 hrs later, still the same thing, i got the impression that something was not rite...then i tried using my other drive, same thing, then i tried trying the first part of the DVD and still the same thing! does anyone have any advice, please post. thanks...
Results 1 to 16 of 16
Wow! You got shocks, pegs... LUCKY!
Hi everyone!
skip2mylou i encountered that problem aswell.
dr divx doesnt convert dvd to divx "on the fly" unless you use anydvd or similar tool, so i was using dvd shrink to copy my dvds to the hard drive
and then converting it to divx.
that specific problem appeared when i decided one time to copy the dvd to my hard drive but without separating the vobs in 0.99 gig chunks.
after i checked the option to separate the dvd in 0.99 gig pieces everything went smoothly again.
ive been using dr divx for a long time and to the date i have yet to find a similar program that can beat it in simplicity and easy of use.Forget Dr DivX-- use AutoGordianKnot
Autogk/auto gordian never worked with me,loads of options confusing and instable, far too much options when the goal is to backup to divx and watch it on a dvd divx player.
9 out of 10 to dr divx.(9 because theres nothing perfect)
last but not least it does work for me -
i c ur fairly new to this site Ricardo, WELCOME
Wow! You got shocks, pegs... LUCKY! -
oh i forgot one thing, in dvd shrink only copy the main movie of the dvd (use the reauthor mode)
in dvd decrypter select file mode and then the option to copy main movie only
dv to divx problem
By anajat in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 19:27 -
H.264 - Divx..... problem !!!
By tjolle62 in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 16:45 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15
