i've downloaded a .md0 , .md1 etc.. format and trying to find a away to burn this onto my dvd disc.. also i have a avi file thats too long when its loaded in tempgnc.. so i need something to cut part of it out so it fit. any software that does an easy job? thanks in advance
.md0? Probably an image file. Try opening it with Isobuster or view it with Daemon Tools. You may be able to burn it with DVDDecrypter or Alcohol 120%.
For editing AVIs, try Virtualdub. You can also frameserve the results from there to TMPGEnc encoder to eliminate the in-between file. If you need to just trim the ends, TMPGEnc can do that. -
i have tried virtuadub and it works fine except that the vocals dont match up...i am trying to find a help for doing it on tmpgenc but no luck , got a link?*edit* just found out using solveig and triming isnt gona work. anything else? i will try out today with what you mentioned for burning the .mdo thx
Best & Fastest Tool To Cut An AVI, MP4 File In The Middle?
By onesikgypo in forum LinuxReplies: 3Last Post: 12th Oct 2013, 21:07 -
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 04:50
