    Nov 2003
    I would like to convert a video in VirtualDub to WMV format; which video compression should I select, or do I need to have some special codec to convert? I want the video small enough so that I can upload it on a website, and I've seen some decent quality wmv files that are low file sizes....
    Dec 2004
    Australia
    You can't do it. VirtualDub can only output avi output.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Why don't you use Windows Media Encoder 9 ?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I seem to recall someone saying the other day that if you have the Windows Media 9 VCM then you can use Virtualdub to output WMV within an AVI container.
    See http://www.microsoft.com/windows/windowsmedia/9series/codecs/vcm.aspx for more details.
    If in doubt, Google it.
    Sep 2001
    Japan
    But if the player can only work with asf/wmv media, you have to covert the AVI with any of these ASFconverters to the ASF format (which is the same as wmv IIRC)
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    IMHO it's probably easier if you have XP to just use Windows Movie Maker or Windows Media Encoder, but the point was that it can be done from within Virtualdub with the VCM.
    Dec 2004
    Australia
    No, you still get an avi. One that just happens to contain WMV9 (fourCC WMV3) video. ffdshow can also encode to WMV3/2/1 and not just to avi, although I am not sure what use a raw stream or OGM would be.
