Can somebody tell me a software that specifically captures stills from video, that gives the best resolution from the video. If anybody can, I would really appreciate.
Results 1 to 11 of 11
Thanks, I never knew Virtualdub had that feature, I mostly using it to encode; thanks again, I really appreciate your help.
Sorry, I am sorry to bother, but how do you exactly use Virtualdub to capture picture stills?
Go to File-->Save image sequence...
and select only one frame on the time line. -
I prefer VirtualDubMod. Just select snapshot from the video menu. ffdshow can also save out images, highly configureable so you can have it save out every 10th frame, a single frame, a range, etc.
Originally Posted by celtic_druid
If you pause the playing software , you could use Mwsnap to grab the sceen shot , and in jpg format , a lot more simpler than using virtualdubs method .
Virtualdub dose bmp and some other format , and saving pictures is a little more complicated than previous posts , because you need to locate the picture frame or frames you want and lock the start and end frames prior to grabbing them , otherwise virtualdub will do the whole file without warning .
Mwsnap is freeware , and handy for those who need snaps to complete guides , snap desktop , window , region , or sleected area . -
You may also use ImageGrab, freeware and efficient.
Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
Multimedia Center, Power DVD, Premiere, and yes Virtual Dub.
In Multimedia Center click the little camera icon.
Same in Power DVD
In Premiere Export as Frame.
Virtual Dub.. ^ yeah what he said. lol
Software to find duplicate pictures
By hamilton accie in forum ComputerReplies: 1Last Post: 29th Apr 2012, 13:49 -
How to find out which software created the video CD I made years ago?
By Tjjjc2 in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2009, 02:28 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
find software to resync. .avi and .srt ?
By neutralidea in forum EditingReplies: 3Last Post: 11th Feb 2009, 21:10 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
