I have looked through the forums and i have not seen a question as specific as mine is so i hope it has not already been answered....I have multiple video files, some avi some mpeg and so on....i have been using dvd santa to convert the files to dvd format for burning but when i select which files to convert, the converted files can either be too big or way too small for the dvd....is there a program that will tell me before i waste a ton of time converting if the converted files will fit on a standard dvd? i also have problems with certain mpeg files, they cannot be converted using dvd santa and the only way to convert them as far as i've found is to convert them to avi and then through dvd santa, is there an easier process especially since converting the certain files to avi has to be done individually to convert all files to dvd without this long hassle....any help would be greatfully appreciated thanks
Rob
If you use VSO DivxToDVD, you can add as many files as you want (within reason) and the app will make certain they will fit on a single 4.7GB DVD.
A good rule - Don't add more than 2.5 hours of footage to a DVD. You can go higher, but quality will begin to suffer.
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
.ts file conversion help
By stanislawski in forum MacReplies: 1Last Post: 23rd Jul 2008, 08:06 -
Conversion ends with NO-FILE
By Tobias0815 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 04:31 -
Help with MKV file conversion
By baxterb23 in forum Video ConversionReplies: 31Last Post: 9th Apr 2008, 09:03
