hi all
im trying to putin track numbers on a cd so i can skip though the cd song by song but still have a mix cd i use cool edit pro 1.2 but since i have installed winxp media center cool edit pro cant find my dvd burner
it was ok on win xp pro any help on what might be wrong
just done a mew mix and want to burn it to cd
Another option is to import the mix into Nero, then add index points were you want track selections.
This way the mix will play as one long song but you can jump around the mix to any point where an index was set. -
Even NERO Express will do this as deeinc said. After opening the file in nero go to properties>filters,inedx&splits - you can dropindex points and use them to create the track points. Just Be sure to check the "no pause between tracks" tickbox.
"Quit Playing With The Clock..."
Rudy - Funhouse pinball game -
BTW Some versions of Cool Edit may be freely
upgraded to Adobe Audition.
Cool Edit won't extract audio from CD!?! Is Daemon to blame?
By pijetro in forum AudioReplies: 7Last Post: 26th Apr 2011, 19:53 -
VideoStudio Pro X2 OR Magix Edit Pro 15 Plus ?
By Dash1 in forum EditingReplies: 1Last Post: 25th Jun 2009, 20:26 -
Cool Edit Pro 1.2a
By rixware in forum AudioReplies: 15Last Post: 14th Feb 2009, 19:07 -
How to Stretch audio perfectly using cool edit. how to calculate it
By afcoff in forum Video ConversionReplies: 0Last Post: 9th Feb 2009, 05:22 -
Cool name for new pro video editing app?
By scusa2000 in forum Off topicReplies: 10Last Post: 6th Aug 2008, 20:25
