Got a DVD-R here off a friend who wants to make further copies of a home made family film but it seems the DVD had a faulty burn as both DVD Shrink and DVD Decrypter report errors at the same position. Playing it back on a standalone, a couple of my players stop , but a couple carry on-the picture freezes for about 10 seconds but then carries on and it's fine after that-so the actual part that is faulty is very small and is only a few seconds into the film, so is there any way I can rip the part of the .vob that is OK then rebuild the DVD (I'm ok with the re-building, it's just ripping the ok part out of the faulty .vob I'm not sure how to do)
Results 1 to 9 of 9
Assuming you've tried all DVD Decrypter options (llike agressive mode), the next thing I'd try is ISOBuster. I've had a couple of discs I've had to play (in a player) while I re-recorded them (in a recorder). Ultimately you might have to try something like this, too.
Good Luck! -
is it scratched or a bad disc? you can use vob merge to put all the vobs together into a mpeg2 file, cut out the bad part, and reauthor. it's always worked for me on bad discs.
member since 1843 -
Thanks for the replies, folks..
.. the disc is totally clean-it must have been a burn problem.
The disc has 5 vob files, I've already used vobmerge to merge vob2-5, but I can't get the first vob off the disc onto my hard drive to try and merge it.
Ive tried DVD Decrypter, but I can't see 'aggressive Mode' setting. I've also tried ISO Buster, but it gets to the point where the problem is-(about 1% into the vob) and stops. -
Have you tried using windows exployer to copy the bad VOB file to your hard drive?
RE: DVD Decrypter
Go to Tools/Settings/General. At the bottom of the window locate the REMOVAL METHOD Pulldown. Then select AGRESSIVE. -
Try ripping the "bad" vob with your DVD burner. There normally locked at 2x and are much more likely to rip a "bad" file than a DVD-ROM which is 16x.
This has worked for me on many problem disks. -
I agree with all posts on retrying with Decrypter and Isobuster. One suggestion for reference is that when burning a film, i try to stick to 2x (4x as an absolute max) irrelevant of format of disc.
problems occur if burnt too quickly and also there are a few DVD players that cannot read them that well and you get the problems you described;i.e freezing, jerking and quite often pixelation.
Ripping and verifying with a faulty burner
By ha13may in forum DVD & Blu-ray WritersReplies: 10Last Post: 31st Dec 2009, 16:25 -
faulty DVD-R will not finalize
By joecass in forum DVD & Blu-ray RecordersReplies: 19Last Post: 10th Nov 2009, 19:51 -
What Happens To Faulty CD/DVD's After You Return Them To The Store?
By Nitro89 in forum Off topicReplies: 1Last Post: 1st Nov 2009, 15:44 -
How to copya faulty playable dvd
By decl in forum Authoring (DVD)Replies: 7Last Post: 24th Mar 2009, 12:15 -
Faulty Sony DW-U18A DVD Burner
By Sakuya in forum DVD & Blu-ray WritersReplies: 31Last Post: 3rd Nov 2007, 03:16
