WOW I used dvd shrink and then burned with nero and it looks great, I might not even bother with a menu.
Results 31 to 36 of 36
Is there anything to convert wmv to video_ts (vob files?)like VSO does with avi's?
This is from the VSO website about DivxToDVD:
DivxToDVD Description
DivXToDVD convert your internet movie files to a compatible DVD.
DivXToDVD is a 1 click solution to convert your movie files to a compatible DVD playable on your home DVD player. DivxToDVD supports most popular format such DivX, Xvid, Mov, Vob, Mpeg, Mpeg4, avi, wmv, dv and stream format. It converts your single files into a compliant DVD Video set of files and burns it on a DVD blank media DVD+-R(W). The aspect ratio can be automatically selected or forced to a specific format. The program works for NTSC and PAL video format and create automatically chapters. Multiple audio tracks are supported. The future version will create automatically DVD menu and Subtitles.
Key features :
- Support DivX, Xvid, Mpeg4, Mov, AVI, WMV video format and much more
- Support AC3, DTS, PCM, OGG, MP3 and much more audio format
- Can merge up to 4 hours of data from multiple movies or episodic files.
- NTSC / PAL format or auto
- Widescreen, full screen or auto
- Automatic chapter creation
- Preview mode to check if the source is not damaged
- Quality mpeg2 encoder
- Fast mpeg2 encoder ( up to 60fps )
- Save dvd structure on hard drive or burn to a blank dvd
- Compatible with CopyToDVD
- Multilingual support (...available languages) -
No wonder the program is becoming payware instead of freeware.The future version will create automatically DVD menu and Subtitles.
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 12:40 -
subtitle timing when converted from srt to .sub (for DVD authoring)
By qknet in forum SubtitleReplies: 4Last Post: 10th Oct 2008, 05:22 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 16:29 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 12:09 -
Is this how to make Hi-Def xvids?
By Topher5000 in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 16:05
