I can't keep my resulting SVCD from looking like everything is thin and tall. I still get somewhat of a letterbox result with thin black strips at the top and bottom but they're thinner than the actual DVD. I rip with SmartRipper, then use DVD2AVI and finally TMPGEnc. I burn with Nero. Can someone send me the settings I need to correct this problem or is it something else?
Thanks,
Joe
If you are playing it back with Windows media player it will look like this,and when played on your standalone dvd it will fill out to fill the screen.
Under "aspect ratio" in tmpgenc it should say 4:3 not 1:1
I did the same mistaka as you yesterday
Yes sorry misunderstood you,
under video setting
Aspect setting 4:3
Advanced source aspect ratio: 16:9 (pal or ntsc depending what system you are on)
Video arrange methodusually, depends which version your using) full screen(keep aspect ratio)
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 18:09 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
