Hi folks,
I have a sony rdr-gx 300 and I have the record and video settings set to 4:3 pan scan. After recording from vcr output to either direct composite in or composite in via a tbc output, the playback from the sony fills the entire screen. However, when I playback on my pc within tmpgenc dvd author to reauthor, there is a black margin on the left side approximately 30 pixels and about 10 pixels at the bottom of the screen. This occurs regardless of the whether the input is direct or is from the tbc. Is this normal? I don't really want to re-encode with tmpgenc plus to resize. Also, how come regardless of the record length setting (hq, sp, etc.) the bit rate is always 9800kbps? Is this just the drawbacks of standalone recorders?
TIA, Matt
As 4:3 tv's overscan the input signal, this will most likely never be an issue when viewing the video on a regular tv. But if you ever watch them on your pc or get a new widescreen tv it may be. The border is most likely part of the config of the unit when recording in 4:3 mode.
The bit rate issue also appears across several different units, so it appears to just be the way they are configured.Google is your Friend
DVD aspect ratio & file size alters in video editing software
By Chrismar in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2011, 08:48 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34 -
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 15:17 -
ifo edit / Need help in editing DVD transport function & aspect ratio
By chazuke in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2008, 08:58 -
DVD to Ipod resolution & aspect ratio
By lemmy999 in forum Portable VideoReplies: 1Last Post: 18th Jul 2007, 14:47
