Hi All, I have just converted an avi movie with ac3 sound using svcd2dvd RC9b and a wierd thing has happened. During the avi2mpeg part of the coversion an mpeg of 4.03GB was created, as expected. When coversion was complete the finished dvd vobs/ifo files were only half size, the mpeg also ended up at only 1.7GB. Out of curiosity ( dvd-r's are cheap anyway ) I burnt the DVD and played it. The finished DVD was only showing as 45 mins in length and was exactly that, 45 mins, ie half the movie. Oddly at the end of this half-movie the dvd didn't end, just went to freeze-frame, and the sound continued. I had converted using pull-down, widescreen and normal tv setting, and opted for mpeg-audio. During the processing I had clicked the settings button, just to check something, this may have caused this anomoly? I haven't retried because I delete the original avi's straight after i have converted and burnt.
Interesting. Can you email me your log file?
Turn off ffmpegX progress sound after finished conversion
By c.eiermann in forum ffmpegX general discussionReplies: 2Last Post: 2nd Sep 2010, 21:56 -
My video keeps getting cut in half during conversion
By FatalX in forum Video ConversionReplies: 4Last Post: 8th Nov 2009, 10:57 -
conversion loses sound half-way through
By santino_avi in forum Video ConversionReplies: 5Last Post: 21st Oct 2008, 12:35 -
Which menu to return to when a movie is finished?
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 09:53 -
Half a conversion
By error in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 30th May 2007, 18:23
