Does wether or not you can burn subtitles into an mpeg4 file depend on the format of the source material?
I ask because I had a tranport stream file outputted from ProjectX that I wanted to burn some subtitles into. No matter what I did it wouldn't work. The subtitles just would not appear on screen, although the the font of the seconds counter would change with changes in the filters tab. But when I demuxed from projectx to .m2v the subtitles appeared ok...
Things seems to work from an mpg-1 source as well but still not a transport stream - .ts from Projectx
This is using a .srt subtitle file with ffmpegx .9s
And a related question - Other than the font size option is there a way to make the font smaller? Even at 1 the size is to big for my tastes and I would like it smaller.
Thanks, hope you can help.
The subtitles are rendered after the source has been read so the source format should not matter. However, you need to use mencoder engine to burn subtitles. A size 0 is being added to version 0.0.9t.
hmmm,
Well something odd is definately happening here as I just did another test to confirm if it makes a difference. The captured transport stream produces a file with no subtitles. After demuxing that same stream through ProjectX to a .m2v file and encoding the subtitles appear without a problem. (This is using mencoder for everything)
Exact same process for two different types of files (from the same source) and the result is different.
I can send you the end result of the two different sample files if you want, they are less than one MB each.
Originally Posted by major
Yes, send them to major4@mac.com together with the process output for each encoding.
How to position a subtitle in a .srt file ?
By momo1984 in forum SubtitleReplies: 24Last Post: 24th Feb 2019, 05:01 -
Srt subtitle converter
By fits79 in forum SubtitleReplies: 3Last Post: 12th Apr 2012, 05:38 -
How do I get .srt format from my .txt or .sub format?
By Louloudi in forum SubtitleReplies: 0Last Post: 12th May 2011, 04:33 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 15:17
