I have a TV tuner card in my pc and I have captured some videos with it in MPEG2 format, size : 720x576. The captured videos play smoothly on my pc.
Recently I tried to convert them to MPEG4 format using a program. The resultant video has good audio and video quality. Only problem is that some frames seem to have been skipped. The clip will play smoothly and suddenly skip a few frames and go forward. Even when this is happening the audio is playing smoothly. After the video has forwarded a little, the audio and video is perfectly synchronized though. Why is this happening?
I am using CyberLink PowerEncoder MPEG4 AVC Edition to encode the tv caps. into MPEG4 format. The program lists it as H.264 format. I don't have deep knowledge of this subject. The converted file is saved as *.mpg file.
I have tried Dr.DivX but the resultant video has too much quality loss. This H.264 format is the first one that I found which reduces the file size without much apparent loss of video quality. -
Okey...the new h264/avc encoders aren't perfect yet. You can also try Mainconcept H.264 Encoder and Moonlight OneClick Compressor
AVC requires a lot more CPU power to decode.
Cyberlink uses Moonlight's compressor and MainConcept is supposed to be total crap.
I would suggest either Nero Digital or x264. That way you also get to use mp4 as a container.
Question how to extract audio from mpeg4
By jimdagys in forum AudioReplies: 5Last Post: 5th Mar 2012, 11:57 -
Question about comparing AVI and mpeg4
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 10th May 2009, 03:16 -
MPEG1-->MPEG4 / Just a nominal question..
By Gew in forum Video ConversionReplies: 3Last Post: 22nd Mar 2009, 10:34 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 30th Oct 2007, 23:47 -
Question on conversion from VOB files to MPEG4
By donkeyking in forum Video ConversionReplies: 8Last Post: 17th Jul 2007, 16:56
