i have an dvd with 18 episodes when it shows the files it shows 3 vob files so it will let me convert or encode what ever you call it, so ill chop it up so i can do it one by one but everytime i do it, it will chop off the last 3 minutes of the episode. ya get what im saying? anyone know whats up??
You could try DVD Shrink in reauthor mode instead. What sort of output are you after ?
Read my blog here.
what do you mean output? i want to convert the episodes which is vob file to mpeg2 so i can put those in dvdlabpro so i can try to make menus for them. the windvd lets me do it but every time i try it the last part which is like 3 minutes left to the episode always gets cut off. what am i doing wrong??
First, you can i mport vobs into DVD Lab Pro and have it demux them. If you just want to put selected episodes on a disk, use DVD Shrink in reauthor mode to get each episdoe you want into it's own small disk (including a set of vobs), then load these vobs inthe DVD Lab Pro as assets. Let it demux them, create you menus, then compile and burn. All of this is non-destructive, with no recompression or encoding. And it won't miss by 3 minutes.
Read my blog here.
Is each episode it's own title ? If so, I'd use TMPGEnc DVD Author (30 day fully functional free trial). You use the "Add DVD Video" button, then select the 'title' (the episode in this case). Do this for each episode and put each episode into a new track. Config your menu(s). Output. Burn.
If in doubt, Google it.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
