I digitize a lot of old analog video, which I play on a Panasonic AG-1960 or a JVC HR-s9911u and run through a Datavideo TBC-1000. Every so often, I will run across a frame or short series of frames that are, for lack of a better word, "torn." To describe: frame x might have areas where it looks like frame (x-1) is still showing. This is usually accompanied by a lot of interlace-type 'teeth' (if I can repeat this soon, I'll post pics). I am almost certain that the fault lies with the TBC because of the nature of the problem, but is the TBC actually malfunctioning? Could it be a buffer overrun problem? Should I buy a line conditioner? Or is this just one of those things I may have to simply grin and bear? Does anyone else get these types of errors?
Some tapes actually work better without a TBC. Tapes with edge damage for instance. So try patching around your TBC.
Or, it could be the VCR. My JVC HR-S9911 sometimes "tears" the video, while a cheap $50 VCR does not. I don't know enough about the inner working to know why - I just know that it happens.
The sync filters inside the Panasonic ES10 DVD recorder repair tearing errors really well. The only reason I kept it. Use it as a passthrough device only, the DVD recording quality is very mediocre.
Full Frame TBC
By innocenceisdeath in forum RestorationReplies: 9Last Post: 1st Jul 2010, 04:17 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
9911u "TBC" - creates tearing at the top of the frame?
By sphinx99 in forum RestorationReplies: 3Last Post: 8th Mar 2010, 20:17 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 13:21 -
Frame tearing with PC playback
By Twist in forum Media Center PC / MediaCentersReplies: 6Last Post: 26th Feb 2008, 10:46
