    Jan 2003
    Canada
    ok i got a project with dvd lab , i have build all the thing......
    when time arrives to compile the project , it start ok but after a moment dvdlab freeze..... and then all my pc ......
    what happen????
    1 intro clips
    17 clips
    16 menus
    for a total of 4.08 gig.
    here what i have tried:
    alternative multiplexer engine ........ same freeze but a little later
    reinstall dvdlab 1.3.1 .............. same freeze
    test compile ................................... all connections ok
    all videos are ntsc fps /bitrate ..... ok
    i have try several times but seems that dvdlab doesn't freeze at the same place. i get almost done one time ; got my 17 clips vob files ok (temporary files) .
    so what 's wrong ???? a abnormal clips???
    i also try dvdlab pro but it seems that i can't compile my saved project (dvdlab 1.3.1) .
    i have compile succesfully in the past that kind of auhtoring but now i don't know what to do more.
    any help will be much appreciate. thx
    Apr 2004
    Miskatonic U
    Did you demux the vobs when you imported them, as recommended by DVD Lab ? If not, I would start be reimporting and demuxing.
    Read my blog here.
  3. Are all assets identical?
    Did you mess with the chapter menus?
    Did you test compile to see if your menu structure is OK?
    Cheers, Jim
    My DVDLab Guides
    Jan 2003
    Canada
    thx for your reply guys ,
    yes to all of you.
    but problem solved ( i think)
    after a full scan , i found a little virus .
    after erasing it , the compilation work perfectly .
    :P :P :P :P :P :P :P
    thx again
    see ya
