How can I convert a commercial DVD to a DVD mpg2 file?
I want to edit the mpg file using TMPEGEnc DVD Author
What can I do?
Use dvd decrypter to extract the files and dvdshrink if needed then add dvd files to tmpgenc dvd author.
Using DVD Decrypter and Shrink gives me an ISO image.
Is there a way with these software packages to get the video to DVD mpg2 so I can edit it with TMPEGEnc DVD Author -
Use DVDdecrypter in File mode not ISO read mode, and with DVDshrink backup as a Hard Disk folder not an ISO image.
Use Decrypter to rip in file mode. Open the ripped files with TMPEGEnc DVD Author. Wait until after you edit and create new files with TDA, then use Shrink if necessary.
Both Decrypter and Shink will give you either an ISO image or a set of DVD files. I don't remember for sure- but apparently both default to ISO so you just have to tell them if you want files.Originally Posted by Smack2k -
Try this guide; https://www.videohelp.com/forum/viewtopic.php?t=224833. Use DVD Decrypter to rip in file mode then point TDA to the folder it created.
It doesn't matter who you vote for. The government always gets in.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
