When i place a PAL dvd into my DVP-642 the image kind of looks squeezed and their faces are long. Is this my Tv or the Dvd?
Thanks.
Its your encoding method,you need to keep the right aspect ratio.If you d/l it then the movie was encoded wrong.
Does this happen for commercial disks as well ?
Does it happen for NTSC disks ?
If it only for this disk, then Johns0 is right - it's an authoring issue.
If it happens for other disks as well, especially commercial disks, then your player has not been set up correctly. You need to go to the set up menu and look for something probably called display format. Make sure it is set to 16:9 -> Letterbox is you have a 4:3 TV.Read my blog here.
Question about pal on new American TVs
By jimdagys in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2011, 09:58 -
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 19:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 22:59 -
PAL disc question...
By mjl1297 in forum Newbie / General discussionsReplies: 9Last Post: 7th Sep 2010, 16:43 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 10:53
