Results 1 to 30 of 34
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello,
    i recently got Metal Gear Solid 2 for my PC, but after installing an all, my problem is that the screen during gameplay is either like a light green or blue, and u cant see any figures, at first i thought this was the way the game was supposed to be, but after cross referencing with some screenshots, i found that i was mistaken. can anybody give some advice pls. thanks...
    heres a pic
    Wow! You got shocks, pegs... LUCKY!
  2. m8 r u using a ps2 version.if yeah u need an emulator.if not just c whether the gamma settings on the game r rite.btw try 2 run the game on OpenGL mode it gives u a quite gud o/p.
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    Originally Posted by VenGeanCe
    m8 r u using a ps2 version...if not just c whether the gamma settings on the game r rite...btw try 2 run the game on OpenGL mode it gives u a quite gud o/p.
    o i am using the PC version, the ps2 was the only pic i could find on google.
    how can i make sure the gamma settings are rite?
    how can i run the game in open GL mode
    btw, what is a o/p...
    thanks
  4. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    Apparently you arn't the only one with problems: http://www.petitiononline.com/mgs2pc/petition.html. I would suggest getting a PS2 and that game, both MGS2 and MGS3 are worth buying the system alone for...
    Your base? Well, they belong to me now...
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    that bad huh, well i thought i was the only one with the problem, its kinda nice to know that im not alone, but i dont wanna have to wait until KONAMI decides that its time they make a patch for those people who want to play this game. and im not really into the PS2 or its games for that matter simply because, i dont like using money...on video game consoles, at least. not to shoot down your idea studtrooper, its just that im not that kinda guy, but thanks for the input.
  6. Originally Posted by VenGeanCe
    If I could only understand this reply
    Originally Posted by jagabo
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hehe, im sorry VenGeanCe, i dont quite understand it either, can u pls explain, thanks.
  8. well m8 i have played MGS1 well in the video options u can go for either software/openGL/d3d modes.well try em and try 2 change the resolution of ur screen also.
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    see in mgs2, i cant find those options, so ill have to try some other way of finding how to change the res and all. thanks tho...
  10. You might have to wait for a patch or new driver release for you graphic card. Doesn't sound too promising by that post of studtrooper's.
  11. I'm a Super Moderator johns0's Avatar
    canada
    Try the newest or maybe even older drivers for your ti 4200,when i had a ti 4200 it worked fine for me but that was last year,it even runs fine on my radeon 9800 pro.
  12. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    o ok, so do i just go to the NVIDIA and download older drivers and install those? also why would going to older drivers have any effect? thanks
  13. I had a Geforce 5600 256mb card that gave me odd screen colors running Far Cry after a driver update.....had to roll back the driver then 3 months later another driver update did not cause problems.
    My current 9800 pro will give me strange anomolies in the Riddick demo. All-in-all, my experience with "cutting edge" games has ALWAYS been one of cross your fingers and push play. The inevitable patch and driver update solves 90% of the problems- the other 10% has been fixed by a MoBo dirver or BIOS update.
    Dig thru Nvidia.com for legacy drivers and try one after un-installing the current ones.
  14. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    so i guess its recommended in my case to roll back the driver (how much should i roll back, like how many drivers u kno wat i mean), and if that doesnt work, i should wait for a patch or something, cuz i contacted KONAMI, and i havent recieved anything from them, but hey... thanks tho
  15. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok i rolled back my driver (like 1 or 2 back), followed correct procedure, and tried to run game, but i get this error...
    i tried changin screen res settings but same thing, what do i do?
  16. skip mgs2 has got some bugs in the game just go 2 official site mite be they got some patches for the game just d/l em
  17. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i did i went to the official site and all they got is a patch for ATI RADEON cards... i wrote them an email and i havent gotten a reply...
  18. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok now im not even being allowed to play the game, just the error(above) comes up and thats it, omg why is my comp so crappy. sorry to sound frustrated, i just cant stand it when things dont work, u know ...
  19. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    btw i thought it was because of the driver, so i uninstalled the old driver, and installed my driver which i was running before... but the same thing kept happening
  20. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i read somewhere that installing the 30.82 helped in this specific problem for this specific game. so i did and after the installation completed, i tried to run MGS2. i then got this error
    and the screen flashed into LOW COLOR Mode (4 bit), and i couldnt change it..., so i had to power off, and power back on...
    so any advice what i shoudl do next? thanks
  21. Check here: http://www.tweakguides.com and check under Forceware tweaks- might find something to help.
  22. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    o man im kinda skeptical about tweaking...
  23. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    but thanks 4 the advice... !!
  24. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    I'm gonna go out on the limb here, but did you install the latest DirectX (currently 9.0c)? If you haven't, run Windows Update and get it...
  25. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    yep sey daisy, i got it...
  26. Direct x 9.c is ok but your ti4200 can't use any instructions from it anyways. Maybe there is a way to force the game to use direct x 8 instructions but it should be automatic.
    As far as tweking goes- tweakguides is a general settings guide and helps explain each one- especially with the Nvidia control panel. Could be the game is forcing modes not supported by your monitor.?
  27. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    o ok, so im basically just playing around with settings, i dont have to take apart my comp (i got the impression that i had to dismantle my comp, when the site said i had to back eveything up and all that...) do i have to back up and system restore and all? thanks
  28. Member studtrooper's Avatar
    May 2004
    The Beyond Section
    DirectX isn't just about programmable pixle shaders. Even with a DirectX 8.1 card like the 4xxx series, DX9 is REQUIRED with the newest games like Doom III...
  29. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    o ok but i have 9.0c so as far as DirectX, im ok rite, also pls comment on the tweaking concern... thanks. any other suggestions would be greatly appreciated, but as far as for now i would like to knwo how tweaking can solve my problems, and if DirectX has anything to do with it either...
  30. i got a hunch that some of ur diretcX dll's mite be corrupt.as far as the 3d object just go 2 start-->run--->dxdiag and just check whether directX got a prob or ur video drivers.if its got video drivers prob update from the site
