hi,
do i have to do as it says on nec site.
Connect drive to secondary IDE channel as Master, use standard UDMA-2 IDE cable
Disconnect all slave hardware from IDE secondary Master
Update in Windows "Safe Mode"
Under Windows 2000 & XP login as administrator
Update without DMA mode, under Windows XP & 2000 in the device manager - "IDE ATA/ ATAPI controllers", you can switch from DMA to PIO mode
Disconnect all external USB/ FireWire devices.
Deactivate virusscanners, active desktop programs and packetwriting agents
or is this just nec covering themselves?
would like to know if i really have to bother doing all of this?
This is just NEC trying to put out every precaution they can possibly think of. In reality none of this is necessary, they are basically just trying to avoid any source of a system freeze-up during the Firmware flash. I've had a dozen programs running at once and flashed to my NEC 1300 and 2500 countless times in 'standard' Win XP mode, in USB external enclosures no less. Of course I used hacked firmware as well, and yet I've still NEVER had any issues whatsoever.
GE DV1 No Firmware Update What Is Up??
By DJboutit in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2011, 22:16 -
Firmware update after regionhack?!
By little demon in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Nov 2009, 23:50 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56
