Hello,
I have used NeroVision for a while now and recently I had the problem that when creating a DVD from an mpg file, it only creates the 1st VOB file correctly, with audio and video, but the rest of the VOB files only contain audio with a blank video. This has happened with 3 files now, all of which were converted from PAL to NTSC (would this have anything to do?)
Could it be a problem with my source files? If so, how could I check this? The files play perfectly with Windows Media Player.
Any info will be greatly appreciated. Thanks.
try latest version of nervision express.
the source may still be corrupt even if you can play it. check it with virtualdub, under video->scan video.
or try convert with some other tool like divxtodvd.
Burner only creates half a CD
By Clydesdale in forum AudioReplies: 4Last Post: 7th Jun 2008, 14:06 -
1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3
By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 05:10 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33 -
It creates empty files!
By aquasonic in forum ffmpegX general discussionReplies: 15Last Post: 12th Sep 2007, 18:01 -
EDIT! Program only converting 1st VOB file?
By chronic777 in forum DVD RippingReplies: 2Last Post: 17th Aug 2007, 05:14
