Hi, I have an avi video file on my hard drive that i converted to dvd files with dvdsanta. Anyway i burned the files with the latest version of nero express to a dvd-r but when i try and play it in a dvd player it plays 1/4 of it then returns to the mein menu and i have to select 2/4 of the video then3/4 and so on. Anyway i want it to play the whole dvd without having to keep selecting different parts of it to play. I know im doing something simple wrong but any help would be great. Cheers.
Does it play fine on the computer? Meaning, can you play the actual files Santa created before burning.
I asume your burned DVD contains only an AUDIO_TS and VIDEO_TS with the dvd files inside .vob .ifo and such?No DVD can withstand the power of DVDShrink along with AnyDVD! -
It doesn't sound like you are doing anything wrong. If you encoded the single AVI file, and authored the single file, then DVDSANTA should have set it up to play as a single file.
Are the break points at "natural" breaks, or does it just end unnaturally?
I don't know of any authoring package that has the intelligence to actually set the breaks properly.
What settings did you use to encode the AVI?ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 09:08 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
