I have a two problems when I try to convert videos with DIKO 0.78 beta 3.
1. If I try to convert using the built-in FreeEnc encoder the conversion seems to go fine without any errors, and the video files play fine and look fantastic, but when I try to import them into any DVD authoring program (DVD-Lab, TMPGenc DVD Author, Adobe Encore DVD) I get error messages saying the GOP for the videos are too long. Is there a fix? Did I check something I shouldn't have?
2. If I choose to have DIKO author a DVD and create an ISO file it doesn't do it. It will convert the videos but won't create an ISO even though the option was checked. Could this be tied in with the GOP errors? Please help!
Thanks,
Benehrmeis
Results 1 to 1 of 1
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
DIKO 2.47 Temp folder problems
By chirayuw in forum Authoring (DVD)Replies: 1Last Post: 6th Jul 2009, 05:26 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 14:41
