OK, hopefully I can explain this correctly, I have some TV rips (Spongebob)of a show that I acquired for my son that are in divx format. Normally not a problem, but when I input them into TMPGEnc it displays that the Video is 11 minutes long but it shows the audio as 34 minutes long. Now the problem is that TMPGenc thinks the file is 34 minutes long so when I try to combine 8 or so episodes to convert to DVD it adjusts the bit-rate real low because it thinks it's 272 minutes of video. If I watch the videos in a media player on my PC it is only 11 minutes long and plays fine. Is there a way to change what the .avi file is reporting for the audio ??
I tried the video clips in DivxtoDVD and it basically locks up, after you push the button to convert it just does nothing. I'm assuming that's because if I try to combine 8 episodes it thinks it's about 5 hours of video that I'm trying to put on disk.
De-mux the Audio with VirtualDub Saving as .WAV. and use that .WAV when you encode.
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 15:55 -
two films, both supposedly 25 fps, but audio tracks don't match?
By cinesimon in forum Video ConversionReplies: 4Last Post: 13th Apr 2011, 23:10 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 11:13 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 20:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 07:35
