How is the 5.1 dolby surround/digital soundtrack store itself on a media? I mean, if I burn a 3 CD-SVCD movie which is an original DVD-rip converted to MPG, is the 5.1 track kept or is it a normal 2 channel sound?
I can hear sound effects on my rear sattelite speakers in my 5.1 system at home when watching those 3 CD-SVCD's, but I wonder if its the same thing as the "real deal", thats is 5.1 on a DVD?
Hope you understand my question.
SVCD does not support 5.1 surround sound. Only Stereo. However a stereo soundtrack will often contain Dolby pro logic which provides a basic surround effect from stereo audio with an appropriate decoder. Any device that decodes Dolby Digital Ac3 (5.1) is likley to also decode Dolby prologic.
There are 10 kinds of people in this world. Those that understand binary... -
Thanks,
can you or somebody else explain this Dolby Pro Logic-thing a little further maybe? I mean, how it works, and how it "fakes" the true 5.1 surround in SVCD's? -
@Bugster
This is what I found in the official Philips SVCD spec
Surround Sound can either be realized by coding a Dolby Surround matrix encoded two-channel audio source with MPEG-1 Audio, or optionally by coding a 5.1 channel audio source with MPEG-2 multi-channel (5+1) Backwards Compatible audio. This mode is defined in the MPEG-2 Audio standard ( ISO/ IEC 13818-3), and is fully compatible with MPEG-1. A MPEG-1 decoder will decode the basic stereo (left and right) audio from the multi-channel MPEG-2 audio signal. So it's an option to add a MPEG-2 multi-channel decoder. -
Originally Posted by bacardi/avt
You could always rip the track (VCDEasy) and analyze the stream (MPEGID) to see if it's 2ch or 5.1/7.1 ch.
If you wanted to create this yourself, or convert from an AC3 5.1 source, I would suggest Hypercube Transcoder.
Scott -
@bacardi/avt, yes, you are right. I forgot, SVCD does support 5.1 audio if it is multi channel mp2. I wish you luck finding a DVD player or decoder that supports it though! They do exist, but are very rare.
What I should have said is that SVCD does not support Dolby Digital (AC3) surround sound, only mp2 which may contain dolby prologic.There are 10 kinds of people in this world. Those that understand binary...
Sound on Sony BD Player Question
By LTCSZ in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Jan 2012, 18:07 -
Question about sound
By slaughteraus in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2011, 01:51 -
Sound problem question
By mysts in forum ComputerReplies: 3Last Post: 20th Apr 2009, 14:13 -
question about how to delay or advance sound/audio on DVD
By jimdagys in forum Newbie / General discussionsReplies: 17Last Post: 10th Dec 2007, 00:08 -
question about no sound when I convert with Avidemux
By jimdagys in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 13:54
