I have an AVI file of a 45-minute TV show. Its current dimensions are 960x528. Its filesize (700MB) is roughly twice that of other episodes of this show (350MB, dimensions of 608x336).
What would be the best possible method for reducing the dimensions of the 700MB episode in order to reduce the filesize to be at least close to the 350MB episodes? I would like all of these files to be uniform in size and dimensions, for archival purposes. Will I compromise much video quality, or will the quality of this 700MB file be equivalent to the 350MB file, once it has been reduced? Is there a different way to achieve these results?
FYI, both the 700MB and 350MB files are DVD-rip quality, as they are from an HDTV source.
Thanks...
Open the file in virtualdub, resize, re-encode with the same codec as before but at a lower bitrate.
There are 10 kinds of people in this world. Those that understand binary... -
Thanks for the reply. Are there any other settings I should be aware of, such as the direct stream/full processing mode settings in Audio and Video?
To re-encode the video and use the resize filter, you need to set video to full processing mode, then selct your compression codec, configure it, and select th resize filter and configure it too.Originally Posted by hockey2112
Leave audio as direct stream copy.
Once everything is set up, go to file->save avi and wait!There are 10 kinds of people in this world. Those that understand binary...
Converting file w/fixed dimensions to one where only vertical dim is known
By nehickel in forum Video ConversionReplies: 0Last Post: 22nd Oct 2009, 20:56 -
File Dimensions No Longer Show In Windows Explorer
By DarrellS in forum ComputerReplies: 15Last Post: 24th Feb 2009, 00:11 -
Reduce AVi file size
By froggger in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2009, 17:58 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56 -
How can I reduce the file size of an XVID AVI without re-doing it?
By nic2k4 in forum Video ConversionReplies: 2Last Post: 20th May 2008, 15:05
