Hi!
I've made a backup of one of my dvds. But the endresult came out 5mb to big so it wont fit on a 4.7gb disc.
During the process i've used program such as dvd-rebuilder, cce..
I figured that i should just remove some of the subtitles. I used both dvdshrink and InterVideo DVDCopy 3 to remove them, but then i ended up with a non existing subtitle menu in WinDvd which is pretty annoying( and it have never happened before), so my question is
-What's an easy way to remove a couple of subtitles from a dvdr.
Do I have to use ifoedit?
Cheers!
You can also use DvdReMake to remove anything you like (or rather don't like :P ) from the disk.
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:30 -
Premiere Pro CS4 outputs 400MB file from 5MB original?
By J-E-T-S in forum EditingReplies: 5Last Post: 20th Jul 2009, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
