Hi,
I'm using DVD Decrypter to rip a movie DVD to my hard disk.
It has all ripped ok except for the last 1% of the 2nd (of 5) VOB file VTS_01_1.vob. I've retried ripping this file several times each after careful cleaning with rubbing alchohol and have set both 'software retries' and 'hardware retries' to their max. It always stops at the same point which is with just approx. 5MB remaining to copy.
Can anyone suggest what I could try to do next? Is there another ripping tool that may help?
Thanks,
Matt
Try smartripper.
Try a different DVD Drive.If in doubt, Google it. -
Thanks.
Smartripper won't recognize the DVD at all, strange cos DVD Decrypter had no propblems listing the DVD's files, just wouldn't rip the last bit of 1 VOB. -
Are you sure your programs are up to date? How are you ripping it ? In file mode or iso? I would recommend you rip in file if youre not. Thats what works best for me. Good luck
Life is like a pothole, you just have to learn to get around it.
Eclipse ripping problem
By cyflyer in forum DVD RippingReplies: 3Last Post: 29th Nov 2010, 07:35 -
HUGE Ripping Problem...HELP
By mgbatman in forum DVD RippingReplies: 9Last Post: 27th Nov 2010, 02:41 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 19:19 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 07:47 -
DVD ripping problem
By efiste2 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 17:07
