    Nov 2003
    Australia
    I thought that would be easy to extract audio tracks but the extensions and structure is not the same as dvd or others I know
    Does anyone here knows how to extract sounds or audio from such discs? thanks
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    Psound (http://snailrush.online.fr/soft/#PSound) can extract audio from PS2 discs
    It heavily depends on the compression the audio is in on the disc, and whether or not the audio is streamed off the disc.
    If it's streamed, you're pretty much SOL (except for a line-in rip, but that's beside the point). If not, it may be compressed in an archive of some sort. PSound and MFAudio can usually get the job done.
