I have made vcds befor but I'm not happy with most of them
because the files of the avi and mov have diferent resolutions some of them are smaller than 352 x 240 and I want to have them in pal because I'm from Europe.
So how can I convert them to vcd with resizing them?
Oh and what can I do about the ones that are in 15fps?
If you just want to make those files a VCD mpeg, read the tmpegenc tutorial. you can load settings for PAL and make them that resolution, it will also change it to 25fps and not 15.
(read around the conversion tuts to find a mov->mpeg or mov->divx)
