Is it possible to play a video file that is missing the first 512KB?
I did some googling for mpg (when that was my only option) and did not really find anything (expect binary boy but it did not seem to want to work)… Now I got two more files though both are avi. I found avifixp but just to piss me off, it does not work if its missing the beginning of the video…
Are there any solutions?
All I can suggest is that you try loading the file into every piece of software that you have until one accepts it. That's what I do but I always try Womble MPEG-VCR first as that seems the most tolerant of bad files.
Artificial intelligence is no match for natural stupidity. -
no luck...
I even now have yet another file this time it .iso
Over 5gigs for one video, yet I cant even see a single second of it... hmmm -
If I'm not mistaken the first few bytes of a compressed video file contains the referencing info for the file. If that's missing or corrupt, the video file is useless.
How did you lose that 512K? -
It also could be that whoever made the iso, created it wrong. If that's the case the file would be useless.
If you KNOW what the videos properties are supposed to be, you could try this...
Record/Create a valid AVI file of the same or greater size (5GB+), using similar settings--e.g. 29.97fps, 720x480, MSDV codec, etc...
Open both in a Hex editor to see where common byte boundaries are, then select the bytes that include the "good" file's header, and paste/insert it into the beginning of the "bad" file (keeping a backup copy, of course--another 5GB+).
Try opening the resultant file in the numerous editors and see if it's usable then. You may need to use a fourCC editor, etc to tweak the settings if they aren't quite right on the 1st try.
Once it's opened, export a copy of the resurrected file (another 4GB+?). This will then be usable in the usual ways.
Whew!
**Note**: You'll temporarily need about 5x the size of your file to accomodate everything safely. Make sure you've got enough free space.
HTH,
P.S. Use a "filetype" investigator to verify that you actually have the kind of file you think you have. These apps parse the bitstream/contents and pattern-match.
VOBs burned to DVD have sound missing on TV (but play OK on PC)
By martinlest in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2012, 07:17 -
Codec missing. Dont know which one. VLC wont play either.
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2009, 16:48 -
missing sound
By agent222 in forum Video ConversionReplies: 6Last Post: 27th Mar 2009, 10:51 -
missing frames
By carmatic in forum RestorationReplies: 11Last Post: 19th Feb 2009, 22:06 -
Vista Media Player 11 doesn't play MP3 Codec Missing
By mlong30 in forum AudioReplies: 6Last Post: 29th Jun 2008, 11:49
