Hey, i got this Svcd2Dvd software a couple of weeks ago and since then i have tried to convert many vcds and svcds to dvd and none have worked so far. I am using SVCD2DVD 2.0 RC8. I think i am doing everything correct. But everytime i make a movie it will play for a while, whether it be 30seconds, 10minutes or 1hour, but sooner or later they all cut off. Why is it? Someone told me to leave more detail as to what i am doing, so here it goes:
-I add assets
-Extract Mpgs
-Then I click quick dvd
-it goes through the mulitplexing, remultiplexing and sampling audio
As far as the process settings are concerned, I have chosen:
-Standard/Fullscreen/Widescreen Setting
-Convert Pal to NTSC
-Keep Source if AC3
-Merge Title Set
Someone please let me know what I am doing wrong or suggestions?
Well. First i would try the latest version: RC9b. If that still gives you issues then you can email me your log file.
Does the cut off happen when you play the dvd on the PC or your Player or both. What is your DVD player?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yeah i just got rc9b last night, im going to try one right now and if there are problems i will email it to you...thanks
Topher Grace edited all the Star Wars prequels into a single movie
By Noahtuck in forum Off topicReplies: 1Last Post: 28th Mar 2012, 02:16 -
PowerDirector: Extract single scenes from Movie --> HUGE(!) file
By Katzwinkel in forum EditingReplies: 1Last Post: 5th Nov 2010, 17:46 -
dvd burning/convert program which burns both 4:3 and 16:9 for single movie
By vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 04:50 -
I want to backup DVD9 movie to single 4.5G blank disc
By byungsoo in forum DVD RippingReplies: 1Last Post: 6th Oct 2009, 01:09 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 04:40
