Using DVDShrink, when I need to re-author a DVD, I see 2 movie sources, (2 angles). Which one should I choose? Does it matter, or will it be the exact same thing? They're slightly different sizes though. Thanks.
It depends on what the angles are used for. In Star Wars they use the abgles to change the language of the opening back story roll. In Finding Nemo it was for the vidio commentary. In the Lion King it added an extra song. In Aliens, one is the theatrical, the other is the longer Director's Cut. You need to look at the features of the disk and pick the one you want. Generally, if it is an English language release, and the angles are used to alter language somewhere (a'la Star Wars) the the first angle will be English. Otherwise it is very much disk dependent.
Read my blog here.
Trying to choose a new camera
By jlbgt2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2010, 17:41 -
Amateur Camera - Help choose the right one
By Nanflexal in forum Off topicReplies: 4Last Post: 29th Jan 2010, 04:19 -
how do i remove an angle lock from a dvd
By animalia in forum DVD RippingReplies: 1Last Post: 10th Jan 2010, 03:11 -
Mini DV camera: should i use an HD-5050PRO wide angle or stay with DVR-5002
By stacks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2009, 14:50 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44
