I live in Winnipeg (Canada) and I am wondering where I can find 4X media? its getting really difficult to find now with 8X being brought into the market. I don't have the money for a new DVD burner. (I'm planning to wait for recordable drives for the the HD DVD/Blue ray, or whatever is coming next).
Results 1 to 9 of 9
Why not use the 8X media? Your burner will accept it. It just won't burn at 8x.
I got a tip from the Digital Dolphin (www.blankmedia.ca)
Hi SilverBlade
The Pioneer DVR-105 is a pretty old drive now... it will probably work "ok" on some 8x DVDRs, but you will almost certainly see better results from actual 4x media. It might be a good time to consider upgrading your DVD burner, now that we have reached the maximum speed of DVDR technology (for single layer discs that is).
-The Digital Dolphin
Note the 'will probably work 'ok'' part. I want to have my movies work 'excellent' not 'ok' -
I don't believe that - I think 8X discs burnt at 4X will work fine on your 105 - the only thing is that you might require a firmware upgrade for it to recognise the media codes, but that's about it. After all, the discs are generally 1X-8X, which means that 1X, 2X, 4X, 6X & 8X should all be supported.
If in doubt, Google it. -
Originally Posted by SilverBlade
I should have mentioned, I don't have a credit card, and my bank doesn't have the online servies that the site accecpts
As mentioned you can use any dvd and burn at a lower speed. Calculating price of each is the question, if you buy cheap media divide the total price to the number of good ones to see how much it really costs, buying a good brand on sale works out cheaper and also price of a new drive could be less than a full tank of gas. If you wait for HD most likely have to buy new computer too. I had the debate with myself too, now I just buy it.
I prefer 4X media as well. Its not that my burner can't handle 8X, its my older JVC players will not play anything but a 4X -R. Infact they won't play maxell 4X. Most computer and Office supply stores have 4X, I have no idea what chains are near you. Can ya use a friends credit card ?
Best choice for blank DVD media since Verbatims are hard to find
By alvabass in forum MediaReplies: 7Last Post: 28th Apr 2012, 23:58 -
Does anyone know where to find 321 media classic
By stadelbauer in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2012, 21:43 -
Where to find hard coat media
By snafubaby in forum MediaReplies: 1Last Post: 22nd Nov 2011, 12:29 -
Cant find or see my media cache on After Effects CS4
By afrojavi in forum EditingReplies: 0Last Post: 5th Jul 2010, 18:07 -
Window Media Encoder Can't find codecs
By Ensign in forum Video ConversionReplies: 2Last Post: 18th Jul 2008, 11:33
