Hopefully a simple question, all us guys converting our valuable vhs to dvd, will I presume be able to take those dvd's and easier than the vhs>dvd conversion, "convert" the dvd to HD-dvd in whatever format that takes.
However, what benefit would waiting for the hd-dvd burners to arrive have, or does the inherent quality of the vhs, mean that straight to HD would have little benefit?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
The only difference is you get more hours on the DVD.
VHS at best is "half D1" or 352x480 or 576 PAL interlaced (max 240x480 in lines of resolution analog terms). If you are concerned about future playback, don't skimp on processing these resolutions now. -
Thank you very much for the helpful reply
You might also consider that those VHS tapes will continue to deteriorate so the longer you wait, the harder it will be to restore/preserve.
Buy My Books
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 06:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 21:47
