hi,
after spending a lot of time converting my precious VHS's to DVD's using this method:
capturing D1 PAL mpeg2 8k Iframes with the software that came with my rather cheap card (avertvstudio203) then converting this annoying progressive result to a DVD interlaced compliant one.
Now, after I surfed this site a little bit more I am TESTING Lordsmurfs method capturing with PowerVCRII 3.0: the results are somehow different:
setup: D1 PAL 8k Iframes
*serious audio sync problems, even not corrected by the free tool PVAstrumento
*the result mpeg is recognized as Interlaced by GSpot but as Progressive by DGIndex, so which is telling the truth ?
The main goal of using this PowerVCR is the difference I learned from Lordsmurfs article regarding (Interlace vs Progressive), but If turned to that PowerVCR does not produce interlaced mpegs so whats the whole point of using it (exept for the nice noise removal + smo0thing)?
any help ?
Results 1 to 1 of 1
Good MPEG2 Capture Software
By mcg22 in forum Capturing and VCRReplies: 4Last Post: 26th Jan 2011, 12:36 -
mpeg2 50mbps capture questions
By the1selecta in forum Capturing and VCRReplies: 13Last Post: 30th Oct 2010, 21:22 -
What do I get for my needs - Mpeg2\Ac3 capture?
By Castor troy in forum Portable VideoReplies: 1Last Post: 20th Apr 2008, 17:56 -
MainConcept MPEG2 Capture using 4:2:2 profile
By wiseant in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2007, 14:42 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 24th Aug 2007, 23:49
