i have a pvr 350 that i use to record sporting events and tv shows that i can't watch when they are on at their original times. it seems to do a great job capturing to mpeg2(i guess). If i install virtualdub to help capture home video through my dv camera/firewire port will i have any conflict issues with with my pvr 350 capturing of tv.
You shouldn't have any conflicts between the PVR 350 and your firewire caps. I have no problems with my PVR 250 and firewire camcorder DV caps. I can even capture with both devices at the same time.
VirtualDub may not be a good choice for DV caps though. -
My biggest problem recording many video sources simultaneously on the same machine is audio monitoring. I need to find an audio solution.
I use the simple, and effective, WinDV for firewire.
I have no trouble capping with that, and my Hauppauge at the same time.Cheers, Jim
My DVDLab Guides
Setup Hauppauge WinTV PVR-350
By DaveQB in forum LinuxReplies: 9Last Post: 18th Oct 2009, 23:56 -
A Better Way To Run a PVR-350?
By hech54 in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2009, 00:56 -
PVR-350 Problems
By nealf in forum Capturing and VCRReplies: 23Last Post: 26th Nov 2008, 23:47 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 18:20
