Hi,
I've been capping and converting UK DVB programmes to XviD for a while now, so have some experience, but this one has me stumped...![]()
my usual procedure:
Capped mpeg2 DVB broadcast
PVAStrumento (to demux and compensate any audio/video frame drops)
Mpeg2Schnitt (to cut adverts/trim any unwanted extras)
resulting in synched .mpv and .mpa files
normally id just convert .mpa to MP3 and .mpv to XviD (AviSynth&VDubMod)
but with one recent cap, ive tried encoding the .mpv to XviD many times, but the resulting .avi is constantly over size (794mb instead of ~650mb).
the .mpv contains the correct number of frames, approx. 80948, for 53min : 57seconds length
but if i play the .mpv in BSPlayer the timecode displays 42mins 29seconds
since i don't actually know what the 'problem' is, i dont really know how to fix it
ive tried the following programmes with both remuxed and demuxed files to no avail:
MPEGCorrector
VideoReDo
MPEG2VCR
Womble MPeg Wizard
Pinnacle 9
TMPEG Plus MPEG tools
Can anyone shed any light on what the problem may be?
and if possible any solutions, please
thanyou for your attention
-kipico
thank you all for your replies
@guns1inger
i have tried ReStream
(i tried many apps now, so cant recall them all
@Abond
I use PVAStrumento out of habit, hasnt failed me until now, im not fully aware of the features of DGMPGDec, but use DGIndex to create the .d2v after correcting synch issues with PVASt
@celtic_druid
unfortunately i have 'discard first pass' checked, so cannot answer that particular question
i originally assumed it was a GOP error at some point, but have subsequently tried pretty much all 'GOP fixers' going
i tested 'timefix.exe' on the .mpv file which promptly created 37 indiviual files
as i have no experience of this app i don't really know what that means
tried joining all these separate .mpg's together and the resulting file is 33 seconds shorter and now BSPlayer reports it as 49min39seconds
quite a frustrating problem now
You don't need the 1st pass. The stats file can tell you how big the first pass would have been.
Video duration discrepancy in 'properties'.
By LT2012 in forum Video ConversionReplies: 6Last Post: 20th Apr 2012, 20:06 -
S-Video quality discrepancy
By HPgloss in forum Newbie / General discussionsReplies: 2Last Post: 26th Feb 2012, 10:29 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
discrepancy between dvd shrink and imgburn???
By m-man in forum DVD RippingReplies: 4Last Post: 12th Aug 2008, 15:59 -
Mkv to Xvid 'length problem'
By bassam319 in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 03:08
