RC9b doesn't. TIA
Doesn't pressing auto fit after you load the project get you where you need to be?
Absolutely. But only if I remember. More than once I have found that I forgot. 8)Originally Posted by ChrissyBoy
Then 20 extra minutes of DVDshrink and 4.5GB of extra disk space gets me where I really wanted to be.
Seems strange if you are suggesting that some day the manual will say:
"You can save everything about your project and easily re-run it at a later time, except the Auto Fit setting."
Anyway, that's my little wish.
Comments from others might be appropriate.
Cheers, P-PA
fair point.
I would prefer to apply AutoFit after a project load (automatically) rather than saving the settings for the assets... thoughts?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Having the AutoFit enabled automatically by default would be great , with an option to disable it if you wished. I'd guess that 99% of users normally use AutoFit anyways. & yeah, I've forgotten to click it more than once!
Applying AutoFit after project load seems reasonable to me. I have forgotten to press it a few times as well. Probably it will be neccessary for AutoFit to be applied in this form for the future batch processing option.
ok then.
Autofit not working
By 803082227 in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 30th Oct 2009, 03:57 -
Autofit and 2-pass encoding
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 27th Apr 2009, 18:11 -
Can we override size that is used in AutoFit ?
By madusmacus in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th May 2008, 15:03 -
AutoFit Issue
By CurtisMinBC in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Feb 2008, 16:19 -
No Autofit
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Sep 2007, 04:01
