This one has me stumped.
ATI AIW, Catalyst 5.4 drivers, MMC 8.9
Capture .AVI using MMC (HuffYUV), open video file in VirtualDub, edit, extract .WAV to HD, frameserve .AVI to TMPGenc (m2v+mp2), encode .WAV to AC3, substitute AC3 for MP2, author DVD -- video runs too fast, way ahead of audio.
BUT: capture .AVI using VirtualDub (HuffYUV) instead of MMC (HuffYUV), all other steps identical -- audio and video sync perfectly.
All setup specs (that I am aware of) are identical in both cases -- capture resolution, audio sample rate, sample rate for AC3 conversion versus MP2 conversion, video encoding resolution/bitrate/quality, etc.
Is there something that I am missing in the MMC setup that creates a captured .AVI that is somehow different than VirtualDub? I may just end up sticking with VirtualDub since I got such good final results with it, but I'm just curious about what could be causing the sync problem going the MMC route (I tried this route first from learning how to at DigitalFAQ).
Used TMPGenc DVD Author 1.6 to author, by the way. TMPGenc is a slow encoder, but I'm liking the quality of the results I'm getting and will probably stick with it -- but could the sync problem be occurring in the encoding step, though?
C.K.
Closed Thread
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Trouble ripping video and/or audio
By dexter30 in forum DVD RippingReplies: 8Last Post: 26th Feb 2010, 11:06 -
Audio Sync trouble with Join
By RedDwarph in forum ffmpegX general discussionReplies: 8Last Post: 12th Apr 2009, 08:24 -
Trouble getting video in time with audio
By JayxDee in forum ffmpegX general discussionReplies: 1Last Post: 27th Jul 2008, 08:36 -
audio sync trouble on dvd to avi
By zookeeper525 in forum DVD RippingReplies: 5Last Post: 2nd Sep 2007, 10:23
