Hey gang,
Alright, I have a Canon Elura 80 and when I enable the passthru function and hook up my Sony 8mm via RCA analog inputs all seems to work well without a tape in the Canon, then when I hook up the Canon via firewire and try to use Sony Vegas 5 to capture it won't capture unless I put a tape in the Canon. Then when I instert the tape it only captures what's on the dv tape and ignores the analog 8mm footage.
The only way I've found to make this work is to actually record the 8mm footage to a dv tape and then upload to the computer via firewire dv-avi.
Am I missing something?
Thanks,
Lex
Results 1 to 13 of 13
Don't know about Canon, but Sony has a menu item for AV-DV which has to be set to on. If it is left off they do exactly as your Canon camcorders are doing.
Just try other software which does not start the tape while capturing from your camera.
WinDV maybe?
I use Scenalyzer which has an option to disable the tape transport function of the DV device/camera while capturing.
Maybe there are options for that too in Vegas? -
My recommendation also. I've got a (borrowed) JVC camcorder w/pass through that works great (have to remove tape to make it pass through) and when I tried to capture using (I think) Ulead, the controls were greyed out (in the capture control panel). But I am able to capture using WinDV. So definitely give it a try!Originally Posted by The_Doman
Wow! Thanks for all the great replies. I know that WinDV doesn't work on my system...don't know why, but it just bombs out.
Now I have all the video from the 8mm recorded to DV tape and I've uploaded that via firewire already and I'm was just about ready to fire up TMPGEnc when I decided to gander at my post.
So now, my question would be is it worth trying to figure out the passthru with device control turned off...will it produce better quality?
Thanks,
Lex -
Quality will be exactly the same -- unless there is a defect in your tape which prevents it from being read properly.Originally Posted by dell400sc
How did you upload with firewire? Do you mean by recording to DV tape first? If so, quality will be the same.
Pass through always requires manual control of the analog source and "device control off" on the capture program.. -
guns1inger,
Not yet, but since my firt attempt to record to dv tape is alreading encoding and users say there shouldn't be quality loss, I'll wait for the encoding to stop and give it a try. I will do it this way from now on.
Thanks,
Lex
Canon XH-A1 HDV tape playback via Sony HDR-FX1
By SteveParis in forum Video ConversionReplies: 2Last Post: 6th Jan 2012, 09:25 -
Changing Record Date. Canon S30 AVCHD Files
By Obtong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Nov 2011, 01:36 -
Best HD camcorder that can record onto tape?
By alexh110 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 10th Oct 2011, 10:20 -
Canon Elura - Tape capture between models doesn't work Help?
By jbrajuka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Nov 2010, 06:58 -
Record cable TV to the Canon GL-2...Can it be done and how?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 24th Aug 2008, 11:13
