I have started to do a few films from avi files and whilst going through its process it states full d1.I did read some time ago on here what is was and what was the difference between that and half d1 but cant find it now.
Please if possible can someone post a link of where to find it so i can just get to understand of what it is doing it for.
ALSO
On the author button the default is set to yes use menu and yes burn disc,is there and option to change both of these to no without selecting it every time.
Thanks for the help once again.
Full and Half D1 refer to video sizing. Full D1 being 720 or 704x480(576) and Half D1 being 352x480(576). The theory being at lower bitrates you use Half D1 for improved quality as you are spreading the bitrate through fewer pixels.
Go here:https://www.videohelp.com/dvd
and scroll down to "Technical Info for DVD-Video" for more.
Req. .rv to .wmv converter or .rv player
By naufil in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2009, 05:20 -
Req: Software For A Faster Pc Start
By Teac23 in forum ComputerReplies: 8Last Post: 14th Jan 2009, 10:46 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 10:43 -
REQ : - SOUND Distorted from footage
By mojoeuk in forum EditingReplies: 2Last Post: 23rd Nov 2007, 15:54 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
