Not mentioned anywhere on this forum is a piece of software called "Lets Convert" made by Canopus.
http://www.canopus.us/US/products/Lets_CONVERT/pm_lets_CONVERT.asp
It is simple and captures to Mpeg in real time and is us$50.00, you can set it to capture up to 3 hours at best quality and combined with the picture controller or any other hardware based processor in the chain does a good job.
I have ordered a Mpeg Pro MVR Card as it does apprently do a better job of Mpeg RT Capture and should be a consideration for thos thinking of the advc300 as is similiar price.
I have come to this decision having tried the ATI AIW 9800 pro and been dissapointed.
The comment about subjective quality is bang on, one mans meat etc.
Thanks for being a great forum everyone.
This is Alison Fiske from a wonderful drama called "Helen a Woman of Today", Brit TV 1974 ish, anyone got it-PLEASE!!!!!!!!!!!!!!
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Hmm it's too bad they don't have any screenshots or describe options for encoding.
As for Canopus, is this supposed to work with the ADVC-100?"*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
"2 ghz cpu reccomended for realtime mpeg capture". Software encoding during dv capturing.
Don't think you'd really need this if you have a hardware cap card. Sounds to be geared for camcorder use. Although you probebly could use it with an ADVC-100, it would most likely give you the same results you now employ. -
Having tried the ATI AIW 9800 pro, I can tell you the results using the advc 300 with the picture controller and Lets Convert are better, again a possible subjective view.
I have ordered the Mpeg Pro Mvr card from Canopus as it seems the best way for mpeg RT cApture without spending 1000,s of dollars, we shall see.PAL/NTSC problem solver.
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
ADVC-300 Adjusting Image Settings - Need another ADVC?
By MitchJi in forum RestorationReplies: 0Last Post: 1st Apr 2009, 12:36 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 13:29 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 15:15 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15
