Why 2 different outputs from ASPI checker programs?
I am
having troubles installing ASPI LAYER 4.
I have 2 programs from Adaptec for checking the information on the installation .
Program one is a download directly from Adaptec
In the Adaptec program it lists the following:
Operating System: Win98
Installed component: APIX.VXD WNASPI32.DLL
The area where it said "ASPI properly installed and fully operational" seems to be grayed out.
Program two is a download from another site and it saids Adaptec ASPI Windows 95.
Installed component: APIX.VXD Aspienum.vxd WNASPI32.DLL Winaspi.dll
The area where it said "ASPI properly installed and fully operational. One host adapter has been detected " is not grayed out.
Why do I get two different results??
How many componets need to be loaded ? 2 or 4 ??
SeeYa
Never Say Never (Romeo Void 1981)
Firefox, Thunderbird -
Are you installing 4.6 or 4.71a2?
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
in prog #1 its grayed out because your missing 2 drivers. in program #2 its problly not grayed out because its for win95 which uses different drivers.
so to fix #1 you need to install new aspi drivers and i would suggest not using the newest availble at adaptec use 4.70's -
Thanks for all the help. What it turned out to be was that I must have had a bad install of Win98. I reinstalled Win98 and on the first try it took the ASPI install. I am using the version 4.6.0.102Originally Posted by hellbringer
Just out of curiosity do you know what the difference in file that Ver 4.71a and Ver 4.6.0.102
Both of them share the 2 files
wnaspi32.dll
apix.vxd
What are the other files for version 4.71a??
I have been working on getting this right for 2 day and I think it was all called by my install of my sound card. I noticed that there was reference to a older dll being replaced when I installed the sound card. So it seem that the sound card and a bad install of Win98 seem to be the problem.
Once again thanks for the help.SeeYa
Video file checker
By Dbruce69 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2012, 23:55 -
Mass video checker
By dread in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2010, 16:19 -
Where can I get the FREE sfv checker that looks like a .....
By bob_smitty in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 21:03 -
using sfv checker
By burgkev in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2008, 18:58 -
Google spell checker not working
By gll99 in forum FeedbackReplies: 16Last Post: 16th Sep 2007, 17:38
