  1. Hi, I've a question about an unknown video format: it's .flv
    Someone know this?
    How can I convert it?
    Thank, bye.
    LuKe
  2. Code:
    ffmpeg -i /path/to/crappy.flv -f mp4 -vcodec mpeg4 -b 1200 -acodec aac -ab 128 -y /path/to/Output.mp4
    if it complains about audio, perhaps it is poor quality, mono, low frequency... you can add: -ar 22050 -ac 1
    you can reduce/increase the video bitrate after the -b; you increase/decrease audio bitrate after the -ab
    If you don't have your own compiled ffmpeg, I believe you can use the embedded binary ffmpeg inside ffmpegX.app -I just checked, and yes you can with an older sept2,2004 ffmpeg at least.
    http://ffmpeg.sourceforge.net/ffmpeg-doc.html for further information.
  3. Hej, I would like to convert a .flv movie to something else
    e.g. I am trying to convert this movie http://www.videospark.com/feeds/sumo.flv
    using ffmpegX 0.0.9s. I am trying to convert the movie using this command line
    /Applications/ffmpegX.app/Contents/Resources/ffmpeg -i  sumo.flv  -f mp4 -vcodec mpeg4 -b 1200 -acodec aac -ab 128 -y sumo.mp4
    I get the following output
    ffmpeg version 0.4.9-pre1, build 4736, Copyright (c) 2000-2004 Fabrice Bellard
      configuration:  --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads
      built on Jan  7 2005 02:34:06, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    sumo.flv: could not find codec parameters
    what am I missing? can anyone help? It would be great to get this to work....
    thanks a lot
    -captnswing
  4. $ /Volumes/Applicate/AV\ Utilities/ffmpegX.app/Contents/Resources/ffmpeg -i /Users/me/Desktop/sumo.flv -f mp4 -vcodec mpeg4 -b 1200 -acodec aac -ab 128 -y /Users/me/Desktop/sumo.mp4
    ffmpeg version 0.4.9-pre1, build 4721, Copyright (c) 2000-2004 Fabrice Bellard
    built on Sep 2 2004 08:23:45, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    Input #0, flv, from '/Users/me/Desktop/sumo.flv':
    Duration: N/A, bitrate: N/A
    Stream #0.0: Audio: mp3, 22050 Hz, stereo
    Stream #0.1: Video: flv, 320x240, 15.00 fps
    Output #0, mp4, to '/Users/me/Desktop/sumo.mp4':
    Stream #0.0: Video: mpeg4, 320x240, 15.00 fps, q=2-31, 1200 kb/s
    Stream #0.1: Audio: aac, 22050 Hz, stereo, 128 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    Press [q] to stop encoding
    frame= 403 q=2.0 Lsize= 2203kB time=26.8 bitrate= 673.5kbits/s
    video:1842kB audio:352kB global headers:0kB muxing overhead 0.407142%
    $ ffmpeg -i /Users/me/Desktop/sumo.flv -f mp4 -vcodec mpeg4 -b 1200 -acodec aac -ab 128 -y /Users/me/Desktop/sumo.mp4
    ffmpeg version 0.4.9-pre1, build 4753, Copyright (c) 2000-2004 Fabrice Bellard
    configuration: --prefix=/opt/local --disable-vhook --mandir=/opt/local/share/man --extra-libs=-L/opt/local/lib --enable-mp3lame --enable-libogg --enable-vorbis --enable-faad --enable-faac --enable-a52 --enable-a52bin --enable-gpl --enable-xvid --enable-gpl --enable-x264 --enable-gpl --enable-pthreads --enable-altivec --enable-shared
    built on May 2 2005 22:19:45, gcc: 4.0.0 20041026 (Apple Computer, Inc. build 4061)
    Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 15.00 (15/1)
    Stream #0.1: Video: flv, yuv420p, 320x240, 1000.00 fps
    Stream #0.0: Video: mpeg4, yuv420p, 320x240, 15.00 fps, q=2-31, 1200 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    frame= 403 q=0.0 Lsize= 2206kB time=26.8 bitrate= 674.3kbits/s
    video:1842kB audio:355kB global headers:0kB muxing overhead 0.406640%
    fatboys with pagers, right? Works for me. Top is ffmpegX's ffmpeg, bottom is my Tiger/gcc-4 ffmpeg.
    Maybe check your paths, or don't copy and paste, but hand type it in.
  5. ok, good to know its working in principle. but on my machine (tiger) with the latest ffmpegX installed, I still get the error
    when trying to convert that flv movie. anyone knows what this means?
    thanks
  6. Try the ffmpeg embedded in major's 9q version listed in this post:
    https://www.videohelp.com/forum/viewtopic.php?t=268110
    I was able to convert using that one. Or try another utility based on ffmpeg like MovieGate. version 1.14 had an ffmpeg that could convert the file.
  7. indeed the 9q version of ffmpegX worked!!
    thanks a lot for your help!
