Results 1 to 9 of 9
    Apr 2004
    Australia
    Hi Guys
    I've been burning cds using my dvd burner for a long time. Suddenly few months ago my burner just stopped burning cds but it still burn't dvds. I use nero for burning cds. Everything goes alright, I get the confirmation from nero that the burn't process is successful but when I check the cd there is nothing on it even though I can see the burn't tracks on the cd. I thought it was either computer or software problem so I formated the computer and installed nero again but had the same problem. I have this problem with other burning softwares as well including windows inbuilt burning software. I've got a pioneer dvd burner. please help
    Apr 2004
    Miskatonic U
    It sounds like something pretty fundamental.
    First test - take the burner out of your machine and put it in another one. If it doesn't work there, then you know it's time for a new one. If it does, then it's time to reformet, not install Nero, and get something new.
    Read my blog here.
    Apr 2004
    Australia
    But it works just fine in burning the dvds and I just checked that if I copy a cd it works then as well. It just doesn't work when I try to burn individual files in a cd
    Oct 2003
    scotland
    i had a similer problem try reducing the cd burn speed too 8x speed
    it worked for me that way .
  5. It could be the laser, there are 2 lasers, one for cd's and 1 for dvd's. The cd laser may have went bad. Best way to fix it is with a new burner.
    There is nothing illegal, until you get caught!
    Apr 2004
    Australia
    The laser can't be damaged because when I copy a whole CD it works just fine. it's only when I burn individual file that I have a problem. I've already tried burning at a reduced speed but it still does'n work
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What type of CD are you burning ? Data ? Music ? CD-ROM (UDF) ?
    If in doubt, Google it.
    Apr 2004
    Australia
    Just trying to burn data CDs with some digital photos, some mp3 songs, and some word files
  9. "Simulate" maybe?
