Results 1 to 11 of 11
  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I no longer need or have ever used my A: dirve, what can I do with that slot? Is there anything cool that can go there? What have you done with your A: drive if anything?
    What We Do In Life, Echoes In Eternity....
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    You can mount a plate in front of it to block the hole when you remove your floppy drive and use the brackets to mount a hard drive. Or you could mount a bay bus or fan controller there. Lots of options really.
    FB-DIMM are the real cause of global warming
    USA
    Two things that might be useful; A digital card reader if you have a digital camera, or a front mounted USB, Firewire connection panel.
    Or the old standby, the blank 3.5 panel that came with your PC case?
    I must have ten of those suckers in my junk box.
    I didn't put a floppy in the last two computers I assembled. With a USB flash drive, not much use. I do have a portable USB floppy drive that came with my laptop just in case I ever need to use that type of media again.
  4. im sure u could prob find some kind of lcd screen to go in there to scroll text. you could also build a tray in there that slides out with candy in it or a cup holder.
    a pez dispensor
    put in a mini fireplace
    make a little home for a pet mouse
  5. I use it to install software that comes on a floppy.
  6. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    lol....sweet
  7. Use it to boot your computer from in case of an emergency
    Use it with a ghost boot disk
    Use it with a linux boot disk
    Originally Posted by jagabo
  8. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    You mean you can actually USE that thing? wow.
    Aug 2003
    NE Ohio
    DOS floppy = safest way to flash (bois, video card, burner).
    I suppose you could set up a DOS USB... never tired it though.
    JSB
    Dec 2003
    I haven't seen any small fan controllers, everyone I saw was 5 1/2 inch, the size of a CD drive.
    Thanks Mike
    Jul 2002
    Up in yo' bitch.
    Ash tray maybe?
    Cup holder?
    Leave the slot open and deposit your loose change in there.
