I'm wanting to upgrade my Dell dimension 8200 ram from 256 to 512. I read on the dell website that in order to upgrade I have to remove all old memory and replace with all new. Is this true or can I just add more memory if I have the slots open?
you can just add more memory, there's no need to remove the old one unless you're having problems with it. check that you have available memory slots to add more memory.Originally Posted by etwicky
I have an 8200 and that is not the case.You should open up your PC and check to see if there is a single 256mb chip or two 128 chips. The reason for this is you should upgrade in like increments. If you have two 128 chips then get two more. If one 256 chip then get one of those. Also make sure it is the SAME type of RAM. You can find that out from the DELL website or in your Owners Manual. As I recall it is 800 DDR Ram.
HolmesEliminate the impossible. Whatever remains, no matter how improbable must be the answer.
S. Holmes
Need help with upgrading
By jaywestcwf in forum Capturing and VCRReplies: 2Last Post: 10th Feb 2010, 10:19 -
upgrading to DC30
By jmacky in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2009, 21:18 -
What needs upgrading on my p.c
By minidv2dvd in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2009, 15:12 -
Upgrading firmware
By tee jay in forum DVD & Blu-ray WritersReplies: 3Last Post: 26th Feb 2008, 13:35 -
upgrading to a DL burner
By efiste2 in forum DVD & Blu-ray WritersReplies: 43Last Post: 27th Jul 2007, 01:51
