It can be a side effect of blanking, please run again with "Clear audio/subs status when blanking" unchecked.Originally posted by Gurm
Not every disc, but certainly more than a couple recently. For example, I wanted to back up my Firefly episode discs. They're almost 8GB, and consist of 4 episodes per disc.
Easy as pie! I crank up Vobblanker, set input directory, make two output directories (disc1_1 and disc1_2), and set output to the first of them.
Then I set it to blank episodes 3 & 4 (which conveniently have their own titles), and hit "go".
It thinks for a few minutes, and then it's done.
But when I burn the resulting folder, the English subtitles (stream 1) are on by default. They weren't on the original disc!
That's it, that's the bug. But I've had it happen ... oh, at least 3 or 4 times (not counting the Firefly discs, which all had it) in the past couple months. Someone else asked about it in the DVD->DVD-R forum a few days back, and one of the other regulars there said something like "yeah that happens sometimes when you use Vobblanker", so I kind of thought it was a known issue...?
If you are able to reproduce the problem in 2.0.0.2 , please send me (in a zip file):
- VobBlanker project (File--> Save as)
- VobBlanker log (Save log)
- IFOs before VB
- IFOs after VB
to
jesus_soto_viso ( at ) terra ( dot ) es
TIA,
jsoto
I thought this was from my dvd player. This problem goes back a while. I had to delete my subs so it wouldn't show. I will run it to save the report.
Problem With VobBlanker
By ramimahafza in forum Authoring (DVD)Replies: 1Last Post: 26th Jun 2011, 00:35 -
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 01:52 -
VobBlanker
By jjis in forum DVD RippingReplies: 2Last Post: 5th May 2010, 18:03 -
Lost subtitles replacing PGC with VobBlanker
By *ale* in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2009, 12:17 -
Subtitles not showing up. Perhaps a different process to be taken?
By martylavender in forum SubtitleReplies: 1Last Post: 12th Nov 2008, 17:14
